i have 3 different actual reg blocks which are extended from uvm_reg_block. i want to use a single reg block at a time in my simulation , how to use factory override on 3 reg blocks which are directly extended from uvm_reg_block
example blocks like below:
class A extends uvm_reg_block;
class B extends uvm_reg_block;
class C extends uvm_reg_block;
i want to use one reg block in my env and reuse all my sequences without using any compile ifdefs.
I am not clear on the need to use factory override in this case.
You should instead define a top_reg_block which has all these 3 reg_blocks as sub-blocks.
This top_reg_block would act as your root register block.
Based on this idea for Sub-system level Tb’s we re-use each of the IP’s reg_block as sub-block of our user-defined ss_top_reg_block
we did this top reg block wrapper with sub blocks at subsytem level tb. but my question is how to use only one block at a time instead of creating 3 blocks and building 3 models. IP level, we need to use only 1 block from 3 available reg blocks without using compile defines ifdef.
Within build() function of top reg block you would instantiate these 3 sub-blocks and call configure , build , add_submap for them.
Then in your env ( or any tb component ) you simply need to instantiate the top_reg_block and call it’s build function
Each IP could access the respective register block via top_reg_block_h.ip1_reg_block / top_reg_block_h.ip2_reg_block / top_reg_block_h.ip3_reg_block
What is the actual difference between the uvm_reg_block: A, B and C?
Number of registers?
Different registers’ addresses?
Different functionality of the registers?
It could help in clarifying the need in factory override…
In general, you can’t override a class using the factory unless the base class is registered with the factory, which uvm_reg_block is not. To overcome this limitation, you need to create a common block base class that encapsulates all the members you want to access. This is why it’s crucial to understand the differences between these various blocks.
Hi Dave and Michael,
The difference between these blocks: A block is super set and B/C blocks are sub set of super block A. But when RAL blocks are generated using systemRDL, all 3 blocks are extended from uvm_reg_block independently.
So, i would like to access only 1 block instead of creating and building 3 blocks all the time for my simulations and avoid using ifdef.
