UVM Recipe of the Month - UVM Debug Archived
Join Academy Subject Matter Expert, Tom Fitzpatrick and view the archived May UVM Recipe of the Month - UVM Debug.
Overview:
UVM class-based testbenches have become as complex as the designs they are meant to verify, and are, in fact, large object-oriented software designs. As such, new debugging techniques and tools must be employed, beyond the usual RTL debugging techniques that designers have used for years. Through a combination of coding techniques (as shown in a Verification Horizons 2012 issue, “Better Living Through Better Class-Based SystemVerilog Debug”) and the unique debug facilities in the Questa Verification Platform, this online webinar will show you how to maximize your ability debug your testbench so you can get on with the real task of verifying your design.
In addition - if you are already an Academy Total Access member, get a head start on UVM Debug by reviewing Built in Debug in the UVM Cookbook.
Learn how to:
  • Developing a Strategy for Debug.
  • General SystemVerilog debug coding technique.
  • SystemVerilog Class-based Debug features in Questa.
  • UVM-Specific Debug in Questa.
  • Viewing your testbench structure.
  • Transaction-based debug.
  • UVM Debug utilities.
  • Organizing files and using packages.
View UVM Debug.
Will this be available as a download as due to timezone difference I will not be able to attend in real time.
In reply to peanuts24:
Yes, the UVM Debug Recipe of the Month will be recorded.
The video archive and PDF of the slides will be available shortly after the 24th.
