UVM/OVM Agent Active Passive
In reply to KumarSunilB:
Hi Dave,
Can I have simple example which gives explanation for Active and Passive Agent configuration?
Can you please throw some more light on “This usually happens when you move from a block level test where the interface is at the edge of your block, to a larger unit or system level test and the interface is now internal to the DUT.”?
Regards,
Vishal
