*In reply to rag123:*A couple of problems with your code.
When calling
trans = transaction::type_id::create(“trans”); with just one argument, there is no context for an instance override. You can provide a context by adding second argument this, which uses the current components path, or provide a third argument which defines an absolute path string.
In your base_test, you call set_inst_override_by_type(), which is a method of uvm_component. It is expecting to see a relative path from the current component, and the top level test is always "uvm_test_top.
So you need to coordinate your overrides by whether you want to be setting instances overrides using the existing testbench hierarchy, or some arbitrary path names
Using existing hierarchy:
trans = transaction::type_id::create("trans",this);
set_inst_override_by_type ("env.trans",transaction::get_type(),extended_transaction::get_type());
Using absolute path strings:
trans = transaction::type_id::create("trans",,"hola");
transaction::type_id::set_inst_override(extended_transaction::get_type(),"hola.trans");
