Hello,
//When overriding by type, the ~original_type~ and ~override_type~ are
// handles to the types’ proxy objects. Preregistration is not required.
// When overriding by name, the ~original_type_name~ typically refers to a
// preregistered type in the factory. It may, however, be any arbitrary
// string. Future calls to any of the ~create_*~ methods with the same string
// and matching instance path will produce the type represented by
// ~override_type_name~, which must be preregistered with the factory.
please any one can explain what is mean by preregistration?
