Hi All,
`include "uvm_macros.svh"
import uvm_pkg::*;
class packet extends uvm_component;
`uvm_component_utils(packet)
super.new(name, parent);
class new_packet extends uvm_component;
`uvm_component_utils(new_packet)
class env extends uvm_component;
`uvm_component_utils(env)
packet p;
new_packet np;
uvm_factory factory;
factory = uvm_factory::get();
function void replace();
p = packet::type_id::create("pkt", this);
np = new_packet::type_id::create("new_pkt", this);
$display("before overriding");
p.print;
np.print;
set_type_override_by_type(packet::get_type(),
new_packet::get_type());
$display("after overriding");
p.print;
np.print;
factory.print;
uvm_top.print_topology();
//know the return type
`uvm_info("ENV", $sformatf("Factory returned cmp of type=%s, path=%s", p.get_type_name(), p.get_full_name()), UVM_LOW)
`uvm_info("ENV", $sformatf("Factory returned cmp of type=%s, path=%s", np.get_type_name(), np.get_full_name()), UVM_LOW)
//endmodule
module tb;
env obj_env;
//obj_env = new();
obj_env = env::type_id::create("obj_env", null);
obj_env.replace();
I am trying to understand uvm_factory example, this the output of the code
before overriding
Name Type Size Value
pkt packet - @1830
new_pkt new_packet - @1861
after overriding
pkt packet - @1830
Type Overrides:
Requested Type Override Type
packet new_packet
UVM_INFO testbench.sv(47) @ 0: obj_env [ENV] Factory returned cmp of type=packet, path=obj_env.pkt
UVM_INFO testbench.sv(49) @ 0: obj_env [ENV] Factory returned cmp of type=new_packet, path=obj_env.new_pkt
Before overriding and after overriding, I could see the same output.
Questions:
How can I really validate that, override has taken place?
I tried to pint the return types, but that did not help. How can I use the return types or something effectively to understand override concepts?
Kindly advice 1 and 2
Thank you
