In reply to Prawin kumar:
Hi Prawin,
seq_item_port is already declared in base class uvm_driver which you are extending from. So no need to declare it again in your ac_lpc_driver class.
Also you have declared it as analysis_port which is causing the error. get_next_item is a built in method of seq_item_port and not of analysis_port.
Regards,
Shivakumar
