I am a beginner. I am trying to write a custom UVM driver for a simple valid -ready protocol. Could someone let me know if the logic is correct or proof read and correct the implementation for the interface protocol which is specified as-
- When data is available assert the valid
- Keep the data stable and valid high until ready is asserted
- De-assert the valid once ready is asserted
The interface is given as follows
interface intf
input clk;
logic [15:0] Data;
logic Valid;
logic Ready; //coming from the DUT
endinterface
class req_txn extends uvm_sequence_item;
rand logic [15:0] data;
`uvm_object_utils_begin(req_txn)
`uvm_field_int(data, UVM_ALL_ON);
`uvm_object_utils_end
function new(string name="txn");
super.new(name);
virtual function void do_print(uvm_printer printer);
super.do_print(printer);
printer.print_field_int("data", data, $bits(data), UVM_HEX);
class my_driver extends uvm_driver #(req_txn);
`uvm_component_utils(my_driver)
virtual interface intf vif;
req_txn txn_to_send;
function new(string name="my_driver", uvm_component parent);
super.new(name, parent);
super.build_phase(phase);
if (!(uvm_config_db#(virtual interface intf)::get(this,"","vif", vif)))
`uvm_fatal("my_driver", "Unable to get the vif from config db")
super.run_phase(phase);
forever begin
phase.raise_objection(this);
seq_item_port.get_next_item(txn_to_send);
txn_to_send.print();
@(posedge vif.clk);
vif.valid <= 1 ;
vif.data <= txn_to_send.data;
wait(vif.ready == 1);
@(posedge vif.clk);
vif.valid <= 0;
seq_item_port.item_done();
phase.drop_objection(this);
Thank you for your time.
