I want to write covergroup to check coverage for 16bit register. I want to make sure that all 15 bits transition to “1” state at least once . It can be together or at different time but each bit should go to “1” at least once.
I tried with this but it didnt work. Out of 16 values it only covered for 0. Even though i did see my register going to different values.mac_xoff is 16bit register I want the coverage for.
covergroup mac_nbi_port_xoff_cg;
//coverpoint to check if Xoff is asserted on all ports
port_xoff: coverpoint port_xoff.mac_xoff {
bins mac_xoff[]= {[0:15]};
