Uvm_component_utils with parameters
When you are dealing with parameterized classes in UVM, you need to use the “param” version of the factory registration macros to register with the factory. You can then set the parameters when you create an object. Example code would look something like this:
class my_param_class #(int paramA = 5, string paramB = "hello") extends uvm_component;
   `uvm_component_param_utils(my_param_class#(paramA, paramB))
   //The rest of the class
endclass : my_param_class
class another_class extends uvm_component;
   `uvm_component_utils(another_class)
   my_param_class #(10, "goodbye")  my_class_h;
   //Constructor, etc.
      super.build_phase(phase);
      my_class_h = my_param_class #(10, "goodbye")::type_id::create("my_class_h", this);
   endfunction : build_phase
endclass : another_class
