super.build_phase(phase); // Calls my_monitor's build_phase first
$display("Building my_custom_monitor with additional setup...");
// Custom behavior for this specific monitor
why we mentioning build_phase as virtual?
In uvm base class, build_phase is virtual,so that it is intended to be overridden in the custom uvm class. But again in custom class also why it is need to give a virtual keyword in build_phase?
In SystemVerilog, if the base class declares a method virtual, the method is always virtual in all derived subclasses. The virtual keyword is optional.
Wanted to check with you if my understanding is correct
Since the respective phases are defined as virtual within uvm_component class,
during a successful factory override this helps in calling the respective phases within the overridden component
