Uvm_analysis_imp and uvm_analysis_export
Hi Sudheer,
uvm_analysis_imp is used in components like scoreboard to implement write function.where as uvm_analysis_export is used for hierarchical connections as follows
If you have a uvm_subscriber which is implementing write function which is inside a uvm_scoreboard then here uvm_scoreboard has uvm_analysis_export where as uvm_subscriber has uvm_analysis_imp , then you have to hierarchical connect export to imp i.e uvm_sb.analysis_export.connect(uvm_sub.analysis_imp)
Thanks,
Vikas Billa
