`timescale 1ns/1ps
class c;
bit b1;
bit b2;
task run();
#1 b1 = 0;
#1 b1 = 1;
#1 b1 = 0;
#1;
forever @* begin
b2 = b1;
$display("b1 changed");
forever begin
@b2;
$display("b2 changed");
join_any
disable fork;
module tb;
c c1;
c1 = new();
c1.run();
$finish;
Hi!
The code above does not compile in questasim. The error string is “** Fatal: Unexpected signal: 11.” which is not helpful. If i comment out the $display after ‘b2 = b1’, it does but the process never triggers so b2 never changes. It works as expected with aldec riviera. My question is, is this a tool issue or LRM restriction. Implicit sensitivity lists with class properties are not supported yet maybe in questa?
You can try it on edaplayground EDA Playground
