In reply to saketa:
OK, I vahe a solution for compiling under Windows/cygwin. If you are putting a wrapper around the C-lib function it works. The C-wrapper code is here:
- dpi_sin.c:
# include “math.h”
double dpi_sin(double val) {
return sin(val);
Your SV should look like this. Consider import “DPI-C” …
2. sine.sv:
module sv_ams_sin_voltage_gen(output real sine_out);
import “DPI-C” dpi_sin = function real sin(input real x);
parameter sampling_time = 5;
const real pi = 3.1416;
real time_us, time_s ;
bit sampling_clock;
real freq = 20;
real offset = 2.5;
real ampl = 2.5;
real sin_int;
int count = 0;
always sampling_clock = #(sampling_time) ~sampling_clock;
always @(sampling_clock) begin
time_us = $time/1000;
time_s = time_us/1000000;
assign sine_out = sin_int;
always @(posedge sampling_clock) begin
while (count < 5) begin
freq = freq/2;
sin_int = offset + (ampl * sin(2pifreq));
$display(“freq = %0f, sine_out = %0f”, freq, sin_int);
count++;
$stop;
- compile from the cygwin command line
vlog sine1.sv sin.c -dpiheader sin.h
4 Start the Questa from the cygwin command line:
vsim -c sv_ams_sin_voltage_gen
Note Questa in Gui mode might not run, thus use "vsim -c … "
