Hi All,
Can any please point me to an example code where we say in config DB highest write wins.
For example say there is a variable in driver we want to set. Lets call this variable as “val”. Below are calls made in build phase of each component and according to rule Highest write wins. So Test set should be final value in driver if we display it in driver run_phase , correct ?
Test :- uvm_config_db#(int)::set(null,“uvm_test_top.env.mem_agnt.driver”,“val”,4);
env :- uvm_config_db#(int)::set(uvm_root::get(),“*”,“val”,3)
agent :- uvm_config_db#(int)::set(null,“uvm_test_top.env.mem_agnt*”,“val”,2);
driver :- uvm_config_db#(int)::set(uvm_root::get(),“*”,“val”,1);
uvm_config_db#(int)::get(this, “”,“val”,val);
Please let me know. Thanks
