Understanding Array Reduction methods
Hi Moderators,
I am trying variation of array reduction method sum in a constraint to understand it’s equivalent expression in each scenario. Here is my attempt
Assume that out of C1 to C7 there is only one constraint active
Have listed my queries in the edalink
A1) According to 7.12.4 Iterator index querying, the index type can be either an int or, for an associative array, it’s the same as the type of the array index.
A2) Since addition has precedence over equality, the parentheses don’t affect the result.
A3) Concatenation {} may have the lowest precedence, but the operands of a concatenation are all self-determined. This means that the width of the expression inside the concatenation is determined independently of the right-hand side of the equality. Consequently, the addition is evaluated in the context of a 2-bit width, which has a maximum value of 3, and this value can never equal 10. Therefore, this constraint always fails.
A4) This constraint is equivalent to 1+1+1+1+1, which evaluates to 5. Since 5 is a non-zero value, the constraint considers it a success. A constraint that always evaluates to a non-zero value is considered a non-constraint.
A5) This constraint is equivalent to the expression 0+0+0+0+0, which evaluates to 0. Since the constraint considers a zero value as a failure, it fails.
Thanks Dave.
Two follow up questions
(QA) Consider the following example from 1800-2023 section 18.5.7.2
class C;
rand bit [7:0] A[];
constraint c1 {A.size == 5;}
constraint c2 {A.sum() with (int'(item)) < 1000;}
The constraint c2 will be interpreted as
( int'(A[0])+int'(A[1])+int'(A[2])+int'(A[3])+int'(A[4]) ) < 1000;
Based on A3, shouldn’t concatenation operator be part of equivalent expression ?
LRM should mention the equivalent expression for c2 as
{ (int'(A[0])+int'(A[1])+int'(A[2])+int'(A[3])+int'(A[4])) } < 1000;
In above example although the int’ cast avoids the overflow,
the following example illustrates requirement of concatenation operator
class C_new;
rand bit [7:0] A[];
constraint c1_new {A.size == 5;}
constraint c2_new {A.sum() with (item) < 1000;} // No int' cast
As per my understanding equivalent expression for c2_new wouldn't be ::
( A[0]+A[1]+A[2]+A[3]+A[4] ) < 1000;
Similar to constraint C4 in my edalink,
due to RHS 32' cast would be used for each element causing randomization to succeed
c2_new should be equivalent to { (A[0]+A[1]+A[2]+A[3]+A[4]) } < 1000;
(QB) For C6 and C7 why does the with expression (0 / 1) appear 5 times (same as size) ?
My understanding was that the presence of keywords like item / item.index within
with clause results in iteration through each element / index .
Hence in such cases the with expression appears size number of times
As C6 and C7 don’t have either of these 2 keywords, I expected with expression (0 / 1) to appear only once
Yes, the concatenation operator should be part of the equivalent expression for clarity. However, the LRM section 7.12.3 Array reduction methods does say:
The method returns a single value of the same type as the array element type or, if specified, the type of the expression in the with clause.
Iteration happens regardless of the presence or absence of the item or index keywords
I realized we had a similar discussion in an older thread
