Unable to figure out fix for race condition in uvm driver: any help is very much appreciated
Yes, the signal comes out correctly from the DUT. I’m guessing this happens due to the SV scheduler.
I’ve checked the waves and also set breakpoints in the code.
I also see the DUT generates the signal correctly because when I don’t use the clocking blocks and set a small fix delay after the rising edge of the clock by the time the execution of the code reaches:
if(delay==0 && vif.cb_write.b2b_halt==0) begin //when the simulator reaches here the value of this signal isn't updated yet
the driver sees the correct value in the ‘halt’ signal.
