In my TB, I am setting the env_config in the test using uvm_config _db set. In the sequence I am trying to get this env_config handle using uvm_config_db get, but I am getting compilation error saying “formal and actual do not have assignment compatible data types (expecting datatype compatible with ‘class uvm_pkg::uvm_component’ but found ‘class obs_config_env_pkg::obs config sequence’ instead)”.
I am not understanding why this error is coming since sequence is also an object and the env cfg is also extended from uvm_object.
You shouldn’t try to get() anything from the uvm_config_db() in a sequence since a sequence is an object and doesn’t have a location in the hierarchy that get() can use.
Instead, you should assign the env_config handle from the test when the sequence is created, prior to starting the sequence.
Hi @cgales, one doubt which I have is, why does config_db doesn’t work. Since both are of type uvm_object there is no issue of type incompatibility. Then why does this error comes? Wanted it understand this.
The issue comes from the requirement that the uvm_config_db() needs to know where in the UVM hierarchy the caller exsists, as it uses this information to determine which configuration entry to retrieve. Since sequences (uvm_objects) are passed around the hierarchy (which is why there is no parent), the config_db can’t determine which entry to retrieve.
This is why you should assign the object from the test when the sequence is created.
