Hi I am writing a program to measure toggle coverage for a 8bit variable. The code is as shown below-
The aim of the program is to check for transition as such that if a bit changes to 0->1 and not 1->0 then its coverage will be 50%.
class prac;
rand bit [7:0] x;
module tb;
covergroup x_val with function sample (input bit y);
coverpoint y
bins a = ( 0 => 1 );
bins b = ( 1 => 0 );
endgroup
prac pr;
x_val xv[8];
pr = new();
foreach (pr.x[i])
xv[i] = new;
repeat(1)
pr.randomize();
$display("Value of Generated constraint is %8b",pr.x);
foreach(xv[i])begin
xv[i].sample(pr.x[i]);
foreach (xv[i]) begin
$display("Coverage for bit[%0d] = %.2f%%", i, xv[i].get_coverage());
I am facing issue coverage is coming out to be 0 for all but what I am expecting is 50 for bits which have toggled to 1 and 0 for other bits. The output with constrained value generated is –
Value of Generated constraint is 10111001
Coverage for bit[0] = 0.00%
Coverage for bit[1] = 0.00%
Coverage for bit[2] = 0.00%
Coverage for bit[3] = 0.00%
Coverage for bit[4] = 0.00%
Coverage for bit[5] = 0.00%
Coverage for bit[6] = 0.00%
Coverage for bit[7] = 0.00%
Also, let me know if you have better solution.
Thanks!
