In reply to Michael54:
These messages indicate that somewhere in your environment you are raising and dropping objections frequently, perhaps in a monitor, scoreboard, sequence, etc.
It is recommended to only raise and drop one objection at the test level.
You can use +UVM_OBJECTION_TRACE on the simulation command line to determine where these objections are being raised/dropped.
