Hi All,
My question is what happens when we run a test in ovm. which files it access first? what is the order? like it goes through the test file then sequences and all.
can anyone help?
thanks in advance
Hi All,
can anyone help?
thanks in advance
In reply to nitin273:
To understand this, I suggest you to read UVM user guide chapter 17 and Chapter 9 regarding to predefined component classes and UVM common phases. Some high level information listed here. uvm_test will be a good starting point to understand how the uvm test is specified and executed at first.
The uvm_test virtual class should be used as the base class for user-defined tests. Doing so provides the ability to select which test to execute using the UVM_TESTNAME command line or argument to theuvm_root::run_test task.
For example
prompt> SIM_COMMAND +UVM_TESTNAME=test_bus_retry
The global run_test() task should be specifiedinside an initial block such as
initial run_test();
Multiple tests, identified by their type name, are compiled in and then selected for execution from the command line without need for recompilation. Random seed selection is also available on the command line.
If +UVM_TESTNAME=test_name is specified, then an object of type ‘test_name’ is created by factory and phasing begins. Here, it is presumed that the test will instantiate the test environment, or the test environment will have already been instantiated before the call to run_test().
If the specified test_name cannot be created by the uvm_factory, then a fatal error occurs. If run_test() is called without UVM_TESTNAME being specified, then all components constructed before the call to run_test will be cycled through their simulation phases.
Thankyou for your replies. dave_59 and Lina.Lin
