Hello everyone, Hope you all are doing well.
I was facing some problems with my assertions and can’t seem to find what is wrong.
property out_ready_p;
int len, count = 0;
@(posedge clk) disable iff (reset)
$rose(ready) |-> // Activates when ready rises
##[1:$] (read, count=count+1)[*2] // read can be asserted any time after ready is asserted, First two packets will be DA and SA
##1 (read, len=port, count=count+1) // 3rd packet contains length information
##1 (read, count=count+1)[*1:$] // Continue count whenever read is HIGH
##1 (!ready, $display($time, "ns |out_intf_%d| found read and ready LOW", ID)) // Untill ready is found LOW
##0 (len+4 == count, $display("OutMon%d Count %0d || Len %d", ID, count, len)); // Check if read was HIGH for len+4 clock cycles, before ready is asserted LOW
out_ready_check: assert property (out_ready_p);
The problem is, if count doesn’t match len+4 the assertion does not fail, it remains active. I wanted it to fail. Also the 2nd last display executes 16 times for some reason.
Could anyone kindly let me know what am I doing wrong here.
