Can anyone help to write assertion for the following scenario?
Whenever there is a ACK signal, GNT should be asserted.
property p;
@(posedge clk)
rose(ACK) |-->[1:] GNT
But my doubt is that which if more than one time ACK got asserted, at that time how can I track which GNT corresponds to which ACK?
How to use a counter in this scenario?
As I can understand based on the question is following points :
- Every
ACK increases the counter.
- Every
GNT decreases the counter.
- Ensures each
ACK has a corresponding GNT.
module ack_gnt_assertion(output reg [7:0] ack_counter,input logic clk, reset, ACK, GNT);
// Counter logic
always @(posedge clk or posedge reset) begin
if (reset) begin
ack_counter = 0;
else begin
if (ACK) begin
ack_counter = ack_counter + 1; // Increment on ACK assertion
if (GNT && ack_counter > 0) begin
ack_counter = ack_counter - 1; // Decrement on GNT assertion
// Assertion to check that GNT count should match ACK count
property p_ack_gnt_match;
@(posedge clk) disable iff (reset)
(ACK |-> ##[0:$] GNT); // Ensure every ACK is eventually followed by a GNT
a_ack_gnt_match: assert property (p_ack_gnt_match) else $error("ACK was asserted, but corresponding GNT did not appear!");
// Assertion to ensure ACK count never exceeds GNT count
property p_ack_gnt_balance;
(ack_counter >= 0); // Counter should never be negative
a_ack_gnt_balance: assert property (p_ack_gnt_balance) else $error("More GNTs detected than ACKs!");
