System Verilog Threads
Q. In this I need to disable the fork as soon as the execution of any two threads completed?
module tb;
initial
  fork : A
    begin:Thread1
      $display("Inside Thread 1");
    end:Thread1
    begin:Thread2
      $display("Inside Thread 2");
    end:Thread2
    begin:Thread3
      $display("Inside Thread 3");
    end:Thread3
  join_none : A
You can use the process inbuild class in the system verilog to monitor each process . Using the process the the code will changed like this . please note as per your code the every thread will finish same time i am writing the code will take care if your thread time will change aslo .
// or browse Examples
module tb;
process p1,p2,p3;
initial
fork : A
begin:Thread1
  p1=process::self();
  #1;
end:Thread1
begin:Thread2
  p2=process::self();
  #5;
end:Thread2
begin:Thread3
  p3=process::self();
  #3;
end:Thread3
join_none : A
wait (p1!=null && p2!=null && p3!=null) // waiting for the three process gets the value
   p1.await ;
   p3.await ;
   $display("time of after two process ends",$time);
 disable fork;
if you modifed to this after any two process the disable will work
module tb;
  process p1,p2,p3;
initial
  fork : A
    begin:Thread1
      p1=process::self();
      #8;
    end:Thread1
    begin:Thread2
      p2=process::self();
      #12;
    end:Thread2
    begin:Thread3
      p3=process::self();
      #3;
    end:Thread3
  join_none : A
         p1.await ;
         p2.await;
         p1.await ;
         p3.await;
         p2.await ;
         p3.await;
     join_any
     disable fork;
Interesting solution, but what happens if you wanted to add one or a few more processes? The amount of code you would have add becomes unmanageable. Using a semaphore is straightforward.
Then compare to semaphore number of lines of code this is much more simpler right ?
module tb;
int count ;
initial
fork : A
begin:Thread1
  #8;
  count = count+1;
end:Thread1
begin:Thread2
  #12;
  count=count+1;
end:Thread2
begin:Thread3
  #3;
  count=count+1;
end:Thread3
join_none : A
wait (count==2);
 disable fork;
module tb;
  semaphore sem = new();
initial
  fork : A
    begin:Thread1
      #1;
      sem.put(1);
    end:Thread1
    begin:Thread2
      #2;
      sema.put(1);
    end:Thread2
    begin:Thread3
      #3;
      sema.put(1);
    end:Thread3
  join_none : A
  sema.get(3);
  disable fork;
I am getting error in this code. can you please check once? @dave_59
You have a typo. “sem” vs “sema”
