System verilog constraint associative array
For an associative array can we have a constraint where all its index is odd and the elements at these index are even?
I wrote something like this limiting the size to 10, Is it possible to do it without use of post_randomization?
class odd_index;
	randc bit [5:0] idx[10];
	rand bit [7:0] array[*];
	constraint index {
			foreach(idx[i]) {
				idx[i] %2 == 1;
		foreach(idx[i]) begin
			array[idx[i]] = 2*($urandom_range(0,100));
module check;
	initial
			odd_index o_i = new();
			repeat(1) begin
			o_i.randomize();
			$display("%0p\n %0p " ,o_i.idx, o_i.array);
You cannot modify the number of elements in an associative array with a constraint. You can only modify the number of elements in a dynamic array or queue with a constraint on its size() method.
A better option might be to use pre_randomize().
class odd_index;
  rand bit [7:0] array[int];
	constraint index {
      foreach(array[i]) {
        array[i] %2 == 0;
        array[i] <=100;
	function void pre_randomize();
      bit [7:0] ai;
      for(int i=0;i<10;i++) begin
        assert(std::randomize(ai) with {
          ai % 2 == 1;
          ai <= 100;
        array[ai] = 0;
module check;
  odd_index o_i = new;
  initial
			repeat(1) begin
              assert(o_i.randomize());
			$display("%0p " , o_i.array);
Note: never use the wildcard associative array index [*]–you cannot iterate over the array because a wildcard index has no fixed type.
