Q. For below code I an getting error at @25 without check complete sequnce how tool can through error?
`timescale 1ns/1ps
module axi_awaddr_assertion_tb;
// Signals
logic clk;
logic rst_n;
logic awvalid;
logic awready;
logic \[31:0\] awaddr;
// Clock generation
initial clk = 0;
always #5 clk = \~clk; // 100 MHz clock
// Reset and stimulus
rst_n = 0;
awvalid = 0;
awready = 0;
awaddr = 32’h0;
#20;
rst_n = 1;
@(posedge rst_n);
// VALID AXI behavior (PASS)
@(posedge clk);
awvalid = 1;
awaddr = 32'hDEADBEEF;
// Hold address stable while AWREADY = 0
repeat (3) @(posedge clk);
awready = 1; // Handshake
@(posedge clk);
awvalid = 0;
awready = 0;
// INVALID AXI behavior (to see FAIL)
@(posedge clk);
awvalid = 1;
awaddr = 32'hAAAA5555;
@(posedge clk);
awaddr = 32'hBBBB6666; // ILLEGAL CHANGE - should fail assertion
@(posedge clk);
awready = 1;
#50;
$finish;
// AXI ASSERTION
property awaddr_stable_when_valid;
@(posedge clk)
disable iff (!rst_n)
(awvalid && !awready) ##1(awaddr);
// Assertion instance
assert property (awaddr_stable_when_valid)
else $error(“AXI AWADDR changed while AWVALID=1 and AWREADY=0”);
// Waveform dumping
$dumpfile(“wave.vcd”);
$dumpvars();
Loading snapshot worklib.axi_awaddr_assertion_tb:sv … Done
xcelium> source /xcelium23.09/tools/xcelium/files/xmsimrc
xcelium> run
xmsim: *E,ASRTST (./testbench.sv,73): (time 25 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 65 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 75 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 105 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 115 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 125 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
xmsim: *E,ASRTST (./testbench.sv,73): (time 135 NS) Assertion axi_awaddr_assertion_tb.awaddr_stable_when_valid has failed
Simulation complete via $finish(1) at time 145 NS + 0
./testbench.sv:59 $finish;
xcelium> exit
TOOL: xrun 23.09-s001: Exiting on Dec 27, 2025 at 04:47:31 EST (total: 00:00:01)
Exit code expected: 0, received: 1
