SVA: throught operator
The assertion below is not working as intended.
Spec: When ‘rst_b’ goes high, signal ‘valid’ should also go high and stay high as long as ‘rst_b’ is high. ‘Valid’ should go low in the same cycle that ‘rst_b’ goes low.
Property p_valid;
@(posedge clk)
$rose(rst_b) |-> (valid throughout rst_b) ##0 !valid;
Here, the assertion passes in the second cycle and does not fail if valid goes low while rst_b is1.
Can someone help me understand why the ‘throught’ operator isn’t working in the assertion i wrote.
Nithya
From my paper
Throughout
The syntax for this sequence is: expression_or_dist throughout sequence_expr. The throughout operator specifies that a signal (expression) must hold throughout a sequence
 ( b throughout R_sequence ) is equivalent to
 ( b [*0:$] intersect R_sequence )
// You need one of these 2 identical options
$rose(rst_b) |-> (valid [*1:$] ##1 !valid)] intersect (rst_b[*1:$])  ##1 !rst_b;
$rose(rst_b) |->  !valid [->1]  intersect (!rst_b[->1]) ;
 rst_b            0  1  1  1  1  0
valid             x  1  1  1  1  0
 rst_b[->1]       0  0  0  0  0  1
!rst_b[->1]       1  1  1  1  1  0
Ben Cohen Ben@systemverilog.us
https://systemverilog.us/vf/Cohen_Links_to_papers_books.pdf
Thanks a lot Ben!
Could you please help me understand why ‘throughout’ does not work here?
Read my paper and understand the equivalency of the trhoughtout.
Here you are saying that valid must be true throughout the length of the sequence rst_b that is ONE CYCLE long!
Got it. Thanks, Ben.
Just another suggestion without using throughout
property pp_valid;
  @(posedge clk)
  $rose(rst_b) |-> always (valid === rst_b);
Hi Ben,
Is the 2nd part of the requirement achievable ?
I tried the following
  property p1;
    //@(posedge clk) $rose(rst_b) |-> ( valid throughout $fell(rst_b)[->1] ) ##0 !valid;
    //@(posedge clk) $rose(rst_b) |-> ( valid until $fell(rst_b) ) ##0 !valid;
    @(posedge clk) $rose(rst_b) |-> ( valid throughout (rst_b[*1:$] ##1 $fell(rst_b)) ) ##0 !valid;
 ap1:assert property(p1) $display("T:%0t Pass",$time); else $display("T:%0t Fails",$time);
 always #5 clk = !clk;
    #4 ; rst_b = 1; valid = 1;
    #40; rst_b = 0;
         valid = 0; // Irrespective of whether valid is 0/1. The assertion fails at T:45
    #2 $finish();
Issue?
Link to model?
My apologies. There are 2 requirements in the original question ::
(1) When ‘rst_b’ goes high, signal ‘valid’ should also go high and stay high as long as ‘rst_b’ is high.
(2) ‘Valid’ should go low in the same cycle that ‘rst_b’ goes low.
I tried the following : edalink
However the assertion fails at T:45
Here is one solution which works
property p1;
   @(posedge clk) $rose(rst_b) |-> ( valid throughout rst_b[*1:$] ) ##1 ( $fell(rst_b) && !valid );
EDA Playground code
EPWave Waveform Viewer wave
There is a contradiction with valid in those assertions that fail
