SVA Simple challenge: Write design and SVA for a down counter
In reply to Prabhu Kamalanathan:
[quote]In reply to Tudor Timi:
On the $fell(rst_n) (rst_n is active lo) I can see your point.
However, There are issues with this $fell(rst_n) assertion.
Assume for the moment that you give to a not very experienced designer the following assertion that expressed your requirements on reset:
ap_reset_fell: assert property(disable iff(1’b0) $fell(rst_n) |=> count_out=='1); The designer would then correctly, per this requirement code the following:
	ap_reset_fell: assert property(disable iff(1'b0) $fell(rst_n) |=> count_out=='1);
  logic rst_reg=1'b1;
  always_ff @ (posedge clk) //  or negedge rst_n)
	rst_reg <= rst_n; // needed for the $fell
        if (!rst_n && rst_reg)   count_out <= '1;	// $fell(rst_n)
	else if (ld_enb)         count_out <= data_in;
	else if (count_enb)
	   if (count_out != 0)   count_out <= count_out - 1'b1;
// **** HOWEVER, what I really want is
ap_reset: assert property(disable iff(1'b0) !rst_n |=> count_out=='1);
// BECAUSE, what if after rst_n==1'b0 for 5 cycles, and during that time, I have a ld_enb?
// Above code would load, when I really want the count_out to be reset to zeros.
// So the assertions would work, but the intent is failing.
****** Thus, you do not want a $rose or $fell on the reset signal. ******
Assume for the moment that I have another requirement that states that if
(count_out==0) then with 20 cycles, count_out==0; that puts a limit on the ld_enb and count.
I could code it in one of the following ways:
ap_0to0_in20_bug: assert property(count_out==0 |-> ##[1:20] count_out==0);
// With no default disable, that assertion would fail if I have a reset during the
// This is because count_out is not zero because the reset that forces it back to '1.
// To correct this, you could add the disable iff
	ap_0to0_in20: assert property(disable iff(!rst_n)
// However, I prefer to use the
default disable iff !rst_n;
// and to cancel that effect in special assertions, I set in the assertion
// disable iff(1'b0)
Correct! That is why assertions should be reviewed!
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
