In reply to rkg_:
I may have misunderstood your requirements, but the shift left/right was what I interpreted from your posts.
You need to clearly define the requirements and implement the code accordingly.
You have the right concepts.
If the increment /decrement is ccmplex use a function call from the sequence_match_item e. G,
function bit dec(logic[your _range]:
... // your decrement algorithm
return value; //
property out_bits_decr_prpty;
@(negedge refclk_output) disable iff(!en_reset)
bit v;
(negclk_count > count) && Enable|=>
(1, v=dec(out_bits)) ##0 v;
//mout_bits == {$past(out_bits[2:0]), 1'b0)}; //before
//out_bits == {$past(1'b0,out_bits[3:1])}; // modified
// was: (out_bits < ($past(out_bits, 1));
