what is the difference between below 2 statements . consider that “foo” is register variable and can take 0,1,x,z value . Lets say foo=“x” . What will be output c in both the cases ?
//case 1
c = (foo) ? a: b ;
AND
//case 2
if (foo) c =a
else c =b
Thanks @user60 . Got the answer . I saw there are many good scenarios in this mentioned document .
case1 - when foo =x , c will get x propogated .
case 2 - when foo = x , c will get “b” as a output .
Above output we will get in the simulation .when we come to synthesis . both the cases will give you same output . “x” propgation enabled setup in Simulation will give exact silicon behaviour .
