SV constraints distribution for different Q
Hi ,
I have 4 different port queues .
  1. port 1 Q value [0-79]
  2. port 2 Q value [80-82]
  3. Port 3 Q Value [83-87]
  4. Port 4 Q Value [88-95]
    I have constraints defined for 1,2,3,4 to be in the range as above .
    Now I want to add a distribution rate of 25% to each of the Port Q , how can I achieve that ?
You should show is the constraints you have defined so far, then we can show you the best way to get an even distribution between the 4 ports.
constraint ListA
  foreach ( ListA[Ia] )
   ListA[Ia] <  79 ;
   ListA[Ia] >= 0;
constraint ListB
  foreach ( List[Ia] )
   ListB[Ia] <  83 ;
   ListB[Ia] >= 80;
constraint ListC
  foreach ( ListC[Ia] )
   ListC[Ia] <   88 ;
   ListC[Ia] >= 83;
constraint ListD
  foreach ( ListD[Ia] )
   ListD[Ia] <   88 ;
   ListD[Ia] >= 95;
This is even more confusing.
What do you mean by a distribution rate? How big is each list?
Or do you want one value in the range 0-95 picked so that each of the 4 ranges has a equal probability. For that you would use a dist constraint
rand int value;
constraint equal { value dist {[0:79]:/1,[80:82]:/1,[83:87]:/1,[88:95]:/1}; }
