Could someone help in understanding this problem-
Write SV constraint to distribute 20 Banana between 5 boys and 6 girls such that each person gets atleast one Banana.
This should help you get started
// Since each person gets 1 banana, min. banana a person would get is 1 & max. banana a person could get is 10
class b_dist;
rand bit [3:0] boys[5]; // 5 boys with Max value as 10 ( hence 4-bit )
rand bit [3:0] girls[6] ; // 6 girls wit Max value as 10 ( hence 4-bit )
constraint MIN_B { foreach( boys[i] ) boys[i] >= 1 ;
foreach( girls[i] ) girls[i] >= 1 ;
// Your constraint homework comes here
// Distribute 20 bananas amongst 5 boys & 6 girls via constraint
class container;
rand int unsigned helper[11];
rand int unsigned boys[5], girls[6];
constraint bananas_c {
helper.sum() with(int'(item)) == 20;
foreach(helper[i]) {
helper[i] <= 20; //to avoid overflow pass
helper[i] > 0;
if(i<$size(boys)) //you can move this to post_randomize. way more efficient
boys[i] == helper[i];
girls[i- boys.size()] == helper[i];
constraint order_c {solve helper before boys,girls;}
class abc;
rand bit[7:0] arr[];
bit[7:0] boys = 2;// let boys are represented by number 2
bit[7:0] girls = 3;// let girls are represented by number 3
constraint arr_c{
arr.size() == 20;
foreach(arr[i]){
arr.sum() with (int'(item == boys)) >= 5;
arr.sum() with (int'(item == girls)) >=6;
arr[i] inside {[2:3]};
$display("arr == %p", arr);
endclass: abc
module tb;
abc abc_inst;
abc_inst = new();
repeat(10)
abc_inst.randomize();
There’s no distinction between girls and boys in this problem; there are just 11 people.
rand int people[11]; // index 0-4 boys 5-10 girls
constraint c {
people.sum() with (longint'(item))== 20; // 20 bananas, prevent overflow
foreach(people[person]) people[person] >=1 ; // each person has at least 1 banana
