SV assertion related to req and grant
When req is high , grant should be asserted within 2 to 20 clk cycles until request should be high. In the next clk cycle, req should be low
Can someone help me with above assertion, I have tried the below approach
assert property (@(posedge clk) req |→ ##[2:20] gnt and req[*3:23] ##1 !req);
I am not clear on the 2nd half of the intention. Could you please elaborate ?
Do you expect request / req to remain high till grant is asserted ? ( where grant itself should be asserted within 2 to 20 clks post request going high )
If yes, the following should work
assert property( @(posedge clk) $rose(req) |-> ( req throughout (##[2:20] gnt) ) ##1 !req );
Solution2 using intersect operator
assert property( @(posedge clk) $rose(req) |-> ( ##[2:20] gnt intersect req[*3:23] ) ##1 !req );
EDIT: One need not even calculate the no. of clocks that req is supposed to remain asserted.
// Equivalent expression for throughout using intersect operator
assert property( @(posedge clk) $rose(req) |-> ( req[*1:$] intersect ##[2:20] gnt ) ##1 !req );
