Super.new()in derived class behavior
I’m trying to understand super.new() behavior when its called in the derived class… I was expecting the super.new(value) call in the child class to assign 77 to its variable “value” . Or if it got assigned to base class’s value wouldn’t that still be available to the child class because of inheritence
class BaseClass;
  int value;
  function new (int value);
    $display("function new from BaseClass");
    this.value = value;
  function void display();
    $display("display function from BaseClass = %d", value);
class SubClass extends BaseClass;
int value;
super.new(value);
//this.value = value;
$display("display function from ChildClass = %d", value);
module tb;
BaseClass bc;
SubClass sc;
  bc = new (44);
  sc = new (77);
  bc.display();
  sc.display();
Results:
display function from BaseClass = 44
display function from ChildClass = 0 → Why is this 0 instead of 77?
You’ve made this overly complicated because you’ve declared four variables with the same name–value.
  • BaseClass::value
  • BaseClass::new() value
  • SubClass::value
  • Subclass::new() value
You commented out the assignment to SubClass::value
By declaring SubClass::value, you have hidden BaseClass::value from SubClass::display(). You can still access it explicitly with BaseClass::value. In general, it’s a very bad programming practice to declare class members with the same name in an extended class that exists in its base class.
