In reply to zalak patel:
Sometimes it helps to unroll the foreach loop and sum() reduction to get a better picture of what is inside it.
Unrolling the foreach:
arr.sum() with (int'(item==arr[0])) == (arr[0]==d ? 2:1);
arr.sum() with (int'(item==arr[1])) == (arr[1]==d ? 2:1);
arr.sum() with (int'(item==arr[9])) == (arr[9]==d ? 2:1);
Unrolling the sum() on just the first line:
int'(arr[0]==arr[0]) + int'(arr[1]==arr[0]) + int'(arr[2]==arr[0]) ... + int'(arr[9]==arr[0])
The sum() is counting the number of times the value of arr[0] appears in the remainder of the array. And the constraint is that value can only appear once or twice depending on the value of d.
