Static vs Automatic
In reply to mukul1996:
You are correct, in that the last update which got executed will be the final value.
However, when you call update, you also immediately call $display, so the value is updated with the argument that is passed in and then displayed. There is nothing blocking between the assignment and $display to allow any task switching.
A better example would decouple the update and display:
class a;
  static int b;
  static function void print();
    $display("At time %0d The value of b is = %0d", $time, b);
  static function void update(int c = 0);
    b = c;
    print();
module check();
  a a1;
    a1 = new();
    fork
        #3 a1.update(4); // Update @time 3
        #1 a1.print();   // Display @time 4
        #3 a1.print();   // Display @time 7
        #5 a1.update(5); // Update @time 5
        #1 a1.print();   // Display @time 6
    join
