How do concurrent processes update static properties in a UVM monitor
What static properties?
This seems like an interview question that you did not understand correctly or was not asked correctly.
Hello Dave thanks for responding. I apologize since I forgot to make a reference to the context. I was referring to section 8.9 - Static class properties. Since there is only one version of a static property of a class and is shared, I was wondering how the concurrent access to this variable is handled .
Thanks in advance for your response
There are many situations where multiple processes could write to the same variable–its lifetime is irrelevant. I can say that a static variable is easier to share amongst multiple processes.
SystemVerilog has a few features like semaphores and mailboxes that can help in these situations. UVM as few features that might help you avoid the need to simultaneously write to a shared variables.
Thanks again for your response. Indeed I was thinking about semaphores but I wanted to clarify if there was any built in mechanism in the System Verilog engine for such scenarios since the processing paradigm of HDL’s allow for concurrent processing.
Best regards
Kaberi
