Square matrix of size odd number and no duplicate max element in rows
“each row should have only one max element and rest less than max and can be repetitive”.
Does it mean - in each row only one element should have max value and all other elements must be less than that. ‘max’ is non-repetitive and others can be repetitive?
I made a minor change to make sure max is not repetitive.
     // compute max_values and make unique
     // one element is equal to the max value
     // and check for max element not to be repeated
     foreach (md_array[r]) {
       md_array[r].sum() with (int'(item < max_value[r])) == odd_num-1;;
