Here is the complete code:
There are 2 levels of hierarchy.
class config_object;
rand int unsigned var1, var2;
rand enable;
constraint c_default {
soft var1 == 10;
soft var2 == 15;
constraint c_var1 {
var1 inside {9,10,11,12};
constraint c_var2 {
var2 inside {14,15,16,17};
class test_config;
rand int unsigned var;
rand config_object cfg[2];
constraint c_t_var1 {
solve cfg[0].enable before solve cfg[0].var1;
solve cfg[0].var1 before solve var1
solve cfg[1].var1 before solve var1
if ( cfg[0].enable)
var1 == cfg[0].var1;
else
var1 == cfg[1].var1;
//similar constraint for var2
In the post_randomize function of the config_object, when I print the variables:
config_object[0].enable = 0;
config_object[0].var1 = 10
config_object[0].var2 = 15
config_object[1].enable = 1;
config_object[1].var1 = 12
config_object[1].var2 = 16
test_config.var1 = 12;
test_config.var2 = 16;
Thanks Dave!
