Sequence not starting without raise/drop objection
In reply to cyy0825:
Do you have somewhereelse an objection mechanism implemented. If not the simulation stucks at run time zero.
Thank you.
I don’t have an objection mechanism implemented in other places.
I think I’ve seen somewhere that if there’s no objection raised then the run_phase will just end. That kinda explains it. But then I modified the code a little bit to add a while(1) loop, I saw different results when putting while(1) loop in different places. (Theoretically both case should be able to finish I think?)
  1. Putting it before seq.start, the uvm_info inside the while loop is printed forever and test hang.
  // run_phase - starting the test
    //phase.raise_objection(this);   -------> comment out
    while(1) begin
      `uvm_info(get_type_name(), "Before seq.start", UVM_LOW)  // ----------> New print added
    seq.start(env.mem_agnt.sequencer);
    `uvm_info(get_type_name(), "After seq.start", UVM_LOW) // ----------> New print added
    //phase.drop_objection(this);   --------> comment out
    //set a drain-time for the environment if desired
    phase.phase_done.set_drain_time(this, 50);
  endtask : run_phase
  1. Putting it after seq.start, the uvm_info never printed and test was able to finish (PASS).
    while(1) begin
  endtask : run_phase
