# ** Error: (vsim-7065) Illegal assignment to class work.uvm_pkg::uvm_port_base #(class work.uvm_pkg::uvm_sqr_if_base #(class work.uvm_pkg::uvm_sequence_item, class work.uvm_pkg::uvm_sequence_item)) from class work.uvm_pkg::uvm_seq_item_pull_imp #(class work.top_sv_unit::utmi_pkt, class work.top_sv_unit::utmi_pkt, class work.uvm_pkg::uvm_sequencer #(class work.top_sv_unit::utmi_pkt, class work.top_sv_unit::utmi_pkt))
# Time: 0 ps Iteration: 0 Region: /top_sv_unit File: ../utmi/utmi_agent.sv Line: 24
# ** Error: (vsim-7065) Illegal assignment to class work.uvm_pkg::uvm_port_base #(class work.uvm_pkg::uvm_sqr_if_base #(class work.uvm_pkg::uvm_sequence_item, class work.uvm_pkg::uvm_sequence_item)) from class work.uvm_pkg::uvm_seq_item_pull_imp #(class work.top_sv_unit::wb_tx, class work.top_sv_unit::wb_tx, class work.uvm_pkg::uvm_sequencer #(class work.top_sv_unit::wb_tx, class work.top_sv_unit::wb_tx))
# Time: 0 ps Iteration: 0 Region: /top_sv_unit File: ../wishbone/wb_agent.sv Line: 25
# ** Error: (vsim-8754) Actual input arg. of type 'class work.uvm_pkg::uvm_seq_item_pull_imp #(class work.top_sv_unit::wb_tx, class work.top_sv_unit::wb_tx, class work.uvm_pkg::uvm_sequencer #(class work.top_sv_unit::wb_tx, class work.top_sv_unit::wb_tx))' for formal 'provider' of 'connect' is not compatible with the formal's type 'class work.uvm_pkg::uvm_port_base #(class work.uvm_pkg::uvm_sqr_if_base #(class work.uvm_pkg::uvm_sequence_item, class work.uvm_pkg::uvm_sequence_item))'.
# ** Error: (vsim-8754) Actual input arg. of type 'class work.uvm_pkg::uvm_seq_item_pull_imp #(class work.top_sv_unit::utmi_pkt, class work.top_sv_unit::utmi_pkt, class work.uvm_pkg::uvm_sequencer #(class work.top_sv_unit::utmi_pkt, class work.top_sv_unit::utmi_pkt))' for formal 'provider' of 'connect' is not compatible with the formal's type 'class work.uvm_pkg::uvm_port_base #(class work.uvm_pkg::uvm_sqr_if_base #(class work.uvm_pkg::uvm_sequence_item, class work.uvm_pkg::uvm_sequence_item))'.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./run.do PAUSED at line 11[size=4]Text[/size]
i am having this issue , if anyone have idea to solve this issue please help me , Thanks in Advance
