I’ve used the above code. Still the simulation is getting blocked. After getting the display message from passive monitor, simulation is getting blocked.
Is there any alternate method to pass data from my passive monitor my active agent’s sequence ?? Can we use TLM ports in this scenario ??
Of course you can use a port/export TLM mechanism. But this is not a good solution. Events and barriers are dedicated for synchronisation across several agents.
OK. I’ll check it and update you.
I can give you a working example for your problem. Please give me an email address.
Thanks a lot for your continuous support. I’ve achieved my task of sending data from my RX Passive monitor to TX sequence and also to TX Monitor by using uvm_event_pool.
can you please send your testbench , or code itself ?? . I also want to achieve same thing , but failed to understand , how to do it ?
YOUR testbench might be of great help
In passive agent there is a monitor, which has analysis port.
So from your active agent, subscribe to to that analysis port and get the data from that port.
you can keep and analysis port reference in config db.
There are always several solutions for a problem. But I do not believe it is a good solution to have a permanent horizontal connection between different agents. Additionally this limits the reusability of your agents.
Putting the data to the config_db generates another problem: you do not know when the data are in the config_db.
whenever there will be change in interrupt, monitor needs to send the data to sequence and then i can perform register operations from the monitor status
Please look this code and share your valuable feedback
//////////////transaction class
class interrupt_transaction extends uvm_sequence_item;
`uvm_object_utils(interrupt_transaction)
rand bit [3:0] interrupt;
extern function new (string name = "interrupt_transaction");
function interrupt_transaction::new(string name = "interrupt_transaction");
super.new(name);
class interrupt_mon extends uvm_monitor;
//////////////////////factory registration/////////////////////
`uvm_component_utils(interrupt_mon)
//////////////////////virtual interface //////////////////////
virtual mcu_status_if intr_vif;
interrupt_transaction intr_txn;
function new(string name="interrupt_mon", uvm_component parent);
super.new(name, parent);
endfunction : new
super.build_phase(phase);
intr_txn = interrupt_transaction::type_id::create("intr_txn");
endfunction : build_phase
super.connect_phase(phase);
endfunction : connect_phase
forever
@(posedge intr_vif.McuClk);
intr_txn.interrupt = intr_vif.Interrupt;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.interrupt),UVM_LOW)
endtask : run_phase
function void report_phase(uvm_phase phase);
`uvm_info(get_type_name(), "Interrupt Entering into Monitor", UVM_LOW)
//////////////////////////Sequence////////////////////////////////////////
class interrupt_sequence extends base_seq;
`uvm_object_utils (interrupt_sequence)
interrupt_transaction intr_item;
function new(string name = "interrupt_sequence");
super.new(name);
task body();
intr_item = interrupt_transaction::type_id::create("intr_item");
start_item(intr_item);
assert(intr_item.randomize());
finish_item(intr_item);
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_item.interrupt),UVM_LOW)
if i get the status from monior then i can perform the register operations, please help me to achieve this
/////////////////////////read interrupt controller status
///////////////////////// check intialization is completed or not MCUINITDONE in MCUCL_Reg spec/////
//////////////////////// if it is set mask the init_mask_parm by setting it to 1
If you are interested you can get a code example to share data between a spi monitor and a apb sequence. Please reply on my email christoph@christoph-suehnel.de
I have developed a UVMF testbench for three modules and now need to create a top-level testbench to verify them simultaneously. I plan to use sub-environments, where the input interface of the second module is driven by the output transactions from the predictor of the first module, and similarly, the second and third modules are connected in the same way.
While researching this, I came across this conversation and thought you might be able to help. If you have a working example, it would be greatly appreciated. You can reach me at s.moein.ghayoumi75@gmail.com
