Sending data from monitor to sequence
// --------------------- monitor run phase method ------------------------ //
	//forever
			txn = rx_txn ::type_id::create("txn");
                            txn.array = {10,20,30,40,50}; //assigning some dummy data to my transaction class, as DUT is not yet ready!
	 `uvm_info("RX_MON_DATA", $sformatf("DATA sending from RX MONITOR is : [%p] \n", txn.array),UVM_LOW) // data {10,20,30,40,50} is printing
            ev = ev_pool.get("mon_ev");
            //uvm_event ev = ev_pool.get("mon_ev");
                ev.trigger(txn);
              `uvm_info("TRIGGER_DATA", $sformatf("DATA triggered in  RX Monitor"),UVM_LOW) //This display is printing , after that simulation is getting blocked/hanged!!
endtask : run_phase
// --------------------- sequence ------------------------ //
class rx_reset_seq extends rx_base_seq;
uvm_event_pool ev_pool = uvm_event_pool::get_global_pool();
uvm_event ev;
`uvm_object_utils(rx_reset_seq)
function new(string name = "rx_reset_seq");
	super.new(name);
            ev=new("ev");
task body();
	req = rx_txn ::type_id::create("req");
           	start_item(req);
	assert(req.randomize());
	finish_item(req);
            ev.wait_trigger();
            $cast(req, ev.get_trigger_data());
// How to print my data here ?? ie., how can I print my sent data here ?? ie., {10,20,30,40,50}
endtask : body
Hi chr_sue,
Please see my code, and help me, if I’m doing wrong …
Do we need to create a separate class for uvm_event by extending from uvm_object ?? or not necessary ??
Anticipating a favourable reply from you at the earliest.
