if i call the default sequence on virtual sequencer’s sequencer then it is not working but if call directly on sequencer it is working why this ?
class mem_ibr_test extends mem_base_test;
mem_sanity_seqs sanity_seqs;
mem_fnx_seqs write_seqs;
`uvm_component_utils(mem_ibr_test)
function new(string name="mem_ibr_test",uvm_component parent=null);
super.new(name,parent);
super.build_phase(phase);
//sanity_seqs=mem_sanity_seqs::type_id::create("sanity_seqs");
//uvm_config_db #(uvm_sequence_base)::set(null,"env.v_seqncer.seqncer.main_phase","default_sequence",sanity_seqs);
//uvm_config_db #(uvm_object_wrapper)::set(this,"env.v_seqncer.seqncer.run_phase","default_sequence",mem_sanity_seqs::type_id::get());
super.connect_phase(phase);
function void start_of_simulation_phase(uvm_phase phase);
super.start_of_simulation_phase(phase);
//uvm_config_db #(uvm_object_wrapper)::set(null,"env.v_seqncer.seqncer.main_phase","default_sequence",mem_sanity_seqs::type_id::get());
uvm_config_db #(uvm_object_wrapper)::set(this,"env.agnt.seqncer.run_phase","default_sequence",mem_sanity_seqs::type_id::get());
