In reply to Manikanta Kopparapu:
With below print it does not mean, only first and last index generating conflict.
This is just showing list of constrains/condition involved for constraints conflict.
rand bit[7:0] array_1[0]; // rand_mode = ON
rand bit[7:0] array_1[4]; // rand_mode = ON
constraint addr_unique_values // (from this) (constraint_mode = ON) (arrays_example.sv:118)
(array_1[0] == 0);
(array_1[4] == 4);
constraint WITH_CONSTRAINT // (from this) (constraint_mode = ON) (arrays_example.sv:142)
(array_1[4] == array_1[0]);
See, below result in this i have just changed array from 5 to 10. It shows only array[0] and [9].
rand bit[7:0] array_1[9]; // rand_mode = ON
constraint addr_unique_values // (from this) (constraint_mode = ON) (testbench.sv:4)
(array_1[0] == 0);
(array_1[9] == 9);
constraint WITH_CONSTRAINT // (from this) (constraint_mode = ON) (testbench.sv:27)
(array_1[9] == array_1[0]);
So, as per above example it does not mean only array[0] and array[9] has conflict only.
As, per my understanding during randomization any condition is not satisfying/contradicting randomization fail will come.
In your case original constraints was like below.
constraint addr_unique_values{
foreach(array_1[i]) array_1[i] == i;
//Equivalent
array_1[0] == 0;
array_1[1] == 1;
array_1[2] == 2;
array_1[3] == 3;
array_1[4] == 4;
However, during second randomization by using in-line constraints you are trying to apply different value ( EX:- array[0] = array[4] ).
which is contradicting to original hard constraint.
I hope now its clear to you.
Thanks!
