I am trying to understand the return value of pack(), unpack(), pack_bytes(), and unpack_bytes() in UVM.
I have the following transaction:
class my_trans extends uvm_sequence_item;
`uvm_object_utils_begin(my_trans)
`uvm_field_int(addr, UVM_ALL_ON)
`uvm_field_int(data, UVM_ALL_ON)
`uvm_field_int(wr_en, UVM_ALL_ON)
`uvm_object_utils_end
rand bit [1:0] addr;
rand bit data;
rand bit wr_en;
function new(string name="my_trans");
super.new(name);
Total field width is only 4 bits:
addr : 2 bits
data : 1 bit
wr_en : 1 bit
I then perform:
num_bits = tx.pack(packed_bits);
num_bits = rx.unpack(packed_bits);
Output:
Name Type Size Value
tx my_trans - @165
addr integral 2 'h2
data integral 1 'h0
wr_en integral 1 'h1
UVM_INFO ... pack() : bits=8
UVM_INFO ... unpack() : bits=8
According to the UVM source code:
function int uvm_object::m_unpack_post(uvm_packer packer);
int size_before_unpack = packer.get_packed_size();
packer.unpack_object(this);
return size_before_unpack - packer.get_packed_size();
and
function int uvm_packer::get_packed_size();
return m_pack_iter - m_unpack_iter;
I would expect pack() and unpack() to report the number of bits actually packed/unpacked. Since my object contains only 4 bits of data, I expected the return value to be 4.
However, both functions return 8.
Environment:
Simulator: Aldec
UVM Library: IEEE 1800.2-2020
The same code run with Synopsys UVM 1.2 returns the expected value.
Questions:
Is the return value of
pack()/unpack()in IEEE 1800.2-2020 expected to be byte-aligned? -
Is there a change in packer behavior between UVM 1.2 and IEEE 1800.2-2020?
Am I misunderstanding the API or using it incorrectly?
Could this be a simulator/UVM library issue in Aldec and other simulators?
If anyone can explain the logic they are using for building this APIs?
Any insight would be appreciated.
