I want to write an assertion with this flow:
A is going down for 100ns.
B toggle 20 times, only when A in low.
I need to check that the last edge of B happen at least 20ns before A go to high.
How can I catch the last edge?
Can I write a loop of 20 iterations?
If you don’t have a clock for signals A and B, you can use tasks.
If you have clocks, then you can use SVA
I am showing 2 untested solutions, but they look OK
// A is going down for 100ns.
// B toggle 20 times, only when A in low.
// I need to check that the last edge of B happen at least 20ns before A go to high.
bit a, b;
task automatic toggle;
$realtime b_now;
b_now=$realtime;
int count;
begin // check b
forever begin // while (a==0)
@(b) count++ ;
b_now=$realtime;
@(posedge a)
am_tdiff: assert($realtime - b_now == 20ns);
am_numb: assert(count==20);
join_any
always @(negedge a) toggle();
bit a, b, clk;
property p;
realtime v;
int count;
@(posedge clk) ($fell(a), v=$realtime, count=0) |->
(@(clk) (1, v=$realtime)[*1:$] intersect a[->1]) ##0
$realtime - b_now == 20ns ##0 count==20;
I tried to do it, but understand that the require is different a bit.
A is going down - don’t know for how long.
B should toggle 22 times
I need to check that from last edge of B there are at least 8ns before A will be high.
Tried to rewrite the code you gave, but still not work to me.
This is the code, I’m sure something wrong, but don’t know what.
the requires:
I’m implementing SPI protocol, once CS fall, the SCLK toggle 22 times and after CS rise again.
I want to check from last edge of the clock, CS is stable at least for 8ns.
Hi Ben,
where is count changes in the property you shared
bit a, b, clk;
property p;
realtime v;
int count;
(@(clk) (1, v=realtime)[*1:] intersect a[->1]) ##0
The requirement that ‘b’ should toggle 20 times when ‘a’ is low has 2 possible interpretations
(1) Change in ‘b’ is is checked on each posedge of clk
(2) Change in ‘b’ is is detected asynchronously
Limitation with (1) is that if ‘b’ were to toggle twice b/w 2 posedges of clk Tx & Ty,
sampled value of ‘b’ at Ty would be same as the previous clock Tx (as ‘b’ changed twice)
I feel a more robust solution would be (2) as it detects transition in ‘b’ between 2 clock edge as well
(B)
I found an older post where the logical reasons behind legality are mentioned. For multiclocked ‘intersect’, it’s acceptable if the lhs & rhs sequence start at different clocks (similar to multiclocked ‘and’) However, the issue with multiclocked ‘intersect’ is that the ending of the 2 sequences can’t be guaranteed with non-identical clocks (for multiclocked ‘and’ the 2 sequences could end at different clocks)
task automatic t();
int count=0, pass=0;
realtime vnow=$realtime, vend;
begin @(posedge a); end
begin forever begin
@(b) count++;
vend=$realtime;
join_any;
am_ab: assert($realtime-vend <- 20ns && count ==20);
am_a2a: assert($realtime-vnow == 100ns);
always @(posedge a) t();
I found an [older post]
Correct, multiclocking is is illegal in intersect
ap: assert property(@ (posedge clk) a[*5] and @(b) b[*4] );
Directive ‘ap’ has multiple leading clocks for its maximal property.
ap: assert property(@ (posedge clk) a[*5] and @(posedge clk) 1 ##0 @(b) b[*4] );
OK
bit clk , a = 1 , b ;
always #5 clk = !clk;
property p;
realtime v;
int count;
($fell(a), v=$realtime, count=0) |-> @(clk) ( ($changed(b), count++)[*1:$] intersect a[->1] )
##0 @(posedge clk) $realtime - v == 20ns ##0 count==20;
ap:assert property( @(posedge clk) p);
#14; a = 0; // Antecedent matches at T:15 & consequent starts evaluation
#06; b = !b; // T: 20 'b' toggles for the 1st time
// Assume that 'b' toggles 19 more times before 'a' is asserted
#2 $finish();
Assertion fails at T:15 as lhs of intersect is false whereas rhs matches due to !a[*1]
( RHS a[->1] is equivalent to !a[$0:$] ##1 a )
For intersect to pass both lhs & rhs should match at T:15 i.e the starting clocking event
I believe property ‘p’ is incorrect since it expects $changed(b) to match on every clocking event i.e @(clk)
Since this thread already has a lot of replies I am thinking to create a new one to discuss possible solution using concurrent assertion.
On edalink I don’t see the compilation/elaboration error that you have mentioned.
I observe the fail action block executes at T:15 as per expectations for the two stimulus
Am I missing something ?
Hi Ben,
Wanted to check with you on 2 quick changes
(1) As the task t() should be called only when ‘a’ is deasserted, shouldn’t we write $fell(a) ?
always@(posedge clk) begin
if( $fell(a) ) // Infers clocking event from procedural block
t(); // Call task 't' only when $fell(a) is true
(2) Within the task, shouldn’t we write $rose(a,@(posedge clk)) instead of @(posedge clk) ?
@(posedge clk) would unexpectedly unblock for 0 → X or 0 → Z transition whereas
$rose(a,@(posedge clk) ) would be true only when there 0/X/Z to 1 transition
task automatic t();
int count,pass; // Default value of 0
realtime vnow = $realtime; // Used in 'alow_2_ahigh'
realtime vend = 0; // Will be at default incase 'b' doesn't transition at all
wait( $rose(a,@(posedge clk) ); // Replaced @(posedge a) !!
forever begin
@(b) count++;
vend = $realtime();
join_any;
disable fork; // Added
if( count > 0 ) // True if 'b' toggled at least once
// Check that 'b' toggled 20 times and last toggle of 'b' was at least 20ns prior to $rose(a)
am_ab: assert( ($realtime-vend >= 20ns) && count ==20);
$error("Signal b did not toggle between $fell(a) & $rose(a)");
// Check that 'a' was de-asserted for 100ns
alow_2_ahigh: assert($realtime-vnow == 100ns);
[You] (1) As the task t() should be called only when ‘a’ is deasserted, shouldn’t we write $fell(a) ?
[Ben] Yes, minor mistake, buyt the approach is good
Asserting on an illegal multiply clocked temporal expression. The clock flow cannot change in the RHS of ‘intersect’ operator.
[Ben] I have a tool that doesn’t like it.
We don’t lalk about tools.
In any case, these tyes of problems are not frequent and can be handled with automatic tasks/
