when we don’t use any random variables at this time. if we want to write a constraint. for some pattern like 0 → 1 → 2 → 0.
if 0 comes in the 1st randomization then in next randomization 1 will come and next 2 and next 0 like this the pattern is.
i write this constraint.
std::randomize(a) with {(a==0) -> (a==1) -> (a==2) -> (a==0) ;};
please check the above one whether it is correct or not and explain the above constraint and share your knowledge
In your example ais is random variable. Its value is undefined during randomization. You would have to use a cast const'(a) to refer to its value prior to randomization.
Also you cannot write implication constraints in series like that. It’s the same as writing A < B < C which is the same as (A < B) < C. You could write this as A<B && B<C or A<B;B<C
