Randomizing Frame Size, Packet Size, and Packet ID
In reply to E_R_R:
I can give you suggestions for a few sequences methodologies to look at, but we probably need a few more details.
  • Your picture makes it look like all the packets have the same size, but I’m assuming each packet could be a different size within the same frame or frames.
  • Are the number of frames and packets per frame set at the beginning of the test?
  • Are there cases where there is no data being sent?
https://verificationacademy.com/cookbook/sequences/layering
https://verificationacademy.com/resources/technical-papers/seven-separate-sequence-styles-speed-stimulus-scenarios
