Randomization of array without using rand or any randomize methods
In reply to sruthikrapa:
This appears to be a homework question based on the fact you have used randomize() in your other questions. So I’ll help but not give you a solution
What you need to do create a loop that generate a random value and pushes it onto a queue. Before pushing the value into the queue, you need to check if the value does not already exist inside the queue. If it does , you need to generate a new random value and try again.
